Checkout Page Hangs
Thread begun 8/13/2014 9:56 am by Mike Perry | Last modified 8/19/2014 1:15 pm by Jason Byrnes | 7295 views | 29 replies |
Mike Perry
Checkout Page Hangs
When I click on the Submit button the page hangs on the Progress display.
Database inserts in confirm.php do not happen. No Apache errors or PHP errors reported.
Checkout.php, confirm_cart.php and confirm.php are attached.
Thanks. .
on the checkout oage, lines 205 - 210:
/*?><?php ?><?php */?>
<?php /*?><?php ?><?php */?>
include a space between the php code blocks. that space will cause the redirect to fail.
Mike Perry
That cleared the hang, but now there's another hiccup.
The first time I click the submit button the page dims briefly and then returns to normal. no data is inserted. When I click a second time the page processes, and data is inserted into the DB -- however the childlist is entered twice.with the same data.
on the confirm page, the form action is set to post to another page:
<form class="fallfestCheckout_checkout" id="Payment_fallfestCheckout_checkout" name="Payment_fallfestCheckout_checkout" method="post" action="payment.php">
it should be posting to the confirm page,
also the triggers for all the behaviors are set to trigger on any form post, they should be set to trigger on on the payment submit button being pressed.
Mike Perry
Everything is posting as it should. Thanks. . .
Still getting that false processing the first time I click on submit.
Mike Perry
Here ya go
see PM
on my testing it worked as it should
I Entered the checkout details, and clicked submit to validate the checkout info, then clicked the process payment button, that redirected to the payment.php page.
seems to work as it should for me.
Mike Perry
It didn't flash the first time you clicked the Submit button on the Checkout Page??
