Discounts on unigue items
Thread begun 8/13/2014 7:19 am by jon392819 | Last modified 8/13/2014 12:10 pm by Jason Byrnes | 6365 views | 13 replies |
jon392819
Hi Guys, cant work this out. I have thousands of products. We want to offer a percentage discount on each unique item in the cart based on the qty of that unique item. Not the combined qty of the cart.
Imagine the cart has3 items in it.
if item one has a qty of 5 or more the price of the item is discounted by 5%
If item 2 only has a qty of one its price is not discounted
If item 3 has a qty of over 10 its price per item is discounted by 10%
We are looking to discount every item individually based on their qty in the cart.
I was hoping to create a rule that said something like, get the count of each each unique id in cart, if over 5 apply a discount of 5%
Is this possible. Thanks
Jon
on the calculations tab, create a new calculation as:
discountAmount
(abs([Quantity] >= 5 && [Quantity] < 10)?[Price] * 0.05:0) + (abs([Quantity] >= 5 && [Quantity] < 10)?[Price] * 0.1:0)
then on the discount tab, create a discount as:
Trigger:
Subtotal of column discount amount > 0
calculation:
Subtotal of column discountAmount plus 0
jon392819
Thanks Jason, the above worked super for the 5%. How do add in other qty breakpoints so if an item has qty between 11 and 20 they get a higher discount.
Many thanks Jason
sorry, should have been:
(abs([Quantity] >= 5 && [Quantity] < 10)?[Price] * 0.05:0) + (abs([Quantity] >= 10 && [Quantity] < 20)?[Price] * 0.1:0)
jon392819
Ah, I got it. If I'd engaged my brain for a second I should have gotten that. I presume I can use the example and add other breakpoints like
(abs([Quantity] >= 5 && [Quantity] < 10)?[Price] * 0.05:0) + (abs([Quantity] >= 10 && [Quantity] < 20)?[Price] * 0.1:0) + (abs([Quantity] >= 20 && [Quantity] < 30)?[Price] * 0.2:0)
yup, that's correct.
jon392819
Hi Jason, tried to run the display manager wizard again to include the discount info under each product but get the attached error. Other ecart sites I have do not share the same. Cleared cache but no luck.
Also Jason, is it possible to show the discount applied to each item in the cart.
I also cant work out how the above calculation gets worked out on a unique product. Where in the above does the code get told do this for each item and not the combined qty of the cart?
Apologies for the questions....
J
instead of running the display manager to recreate the desplay use the bindings panel to add the discountAmount amount binding to the cart display.
calculations are performed on a line by line basis, just by doing the discount as a calculation is how you ensure that it is applied to unique items and not the cart total quantity.
jon392819
Thanks Jason, I see the bindings thanks. I think I gave you the wrong idea above. I need to discount to be a percentage of the total cost for the item.
If item x has a price of 1 Euro and it has qty of 3 the discount would be 3 Euro - 5%.
At the minute I think we are just working out the discount on the Item price and taking that from the total.
Also, at the minute when I add two different items to the cart each with a different price per unit and a qty of 6 or more they both get the exact same discount showing. Appreciate this may heading to a premium ticket.
I attach a screen shot. Thanks Jason
Jon
ok, so multiply the price * quantity in the calculation:
(abs([Quantity] >= 5 && [Quantity] < 10)?([Price] * [Quantity]) * 0.05:0) + (abs([Quantity] >= 10 && [Quantity] < 20)?([Price] * [Quantity]) * 0.1:0)
send a copy ofd the cart display page please.
