only last record displayed
Thread begun 8/13/2014 7:03 am by Paul | Last modified 8/14/2014 9:33 am by Jason Byrnes | 3540 views | 13 replies |
Paul
As subject says only the last record is displayed in pro maps.
In Dreamweaver Live view, i can see multiple records displayed on map
At remote server i only see the last mysql db-record being displayed on map
I checked the streetnames and postcodes, there are correct. Could this be a cache issue?
I have pushed all the required folders towards the remote server but without any luck.
"Could this be a cache issue?"
Yes, it could be a cache issue. if you still have the problem after clearing the cache, I'll need to troubleshoot directly, see the private message section.
Paul
Ok, see PM.
the images folder is missing from the server that are used for drawing the push pins, for example:
/webassist/google_javascript/images/pushpin_pacifica.png
make sure to upload the /webassist/google_javascript/images/ folder to the server.
Paul
Oh well that was a quick fix. LOL
i really appreciate your help, Thanks Jason!
A second question. Is there a way of stopping the script to focus not the last record. I just want to load the entire map with places and the user has to focus on a place. I will try to add a default location with coordinates... but i think it will popup a information baloon (i dont want)
in the /webassist/google_javascript/wagmp_map_1.php file, find the following code:
if (isDefault) {
infowindow.open(map1,marker);
setTimeout("google.maps.event.trigger(wagmp_map_1_obj.markers[" + wagmp_map_1_obj.markers.length + "], 'click')",1000);
//map1.setCenter(point);
and comment the infowindow.open(map1,marker); line:
if (isDefault) {
//infowindow.open(map1,marker);
Paul
Yes thats exactly what i was trying to achive, but now i have another issue.
The visitor needs be able to click on the link generated in the Info window.
e.g. when a guest clicks on a push-pins on the map. I would like to show the infowindow.open(map1,marker) :-)
update: i have removed the comment at the infowindow.open(map1,marker); line: -- this is better of what i was trying to achive
only comment the infowindow.open(map1,marker) line that is in the if (isDefault) { if statement.
Paul
I have commented the infowindow.open(map1,marker) line that is in the if (isDefault) { if statement.
When the page is loaded, it still navigates automatically to the last record.
comment the setTimeout line also.
