https address at checkout triggers security warning
Thread begun 8/12/2014 8:52 am by jo271221 | Last modified 12/01/2014 8:10 am by Jason Byrnes | 3129 views | 5 replies |
jo271221
I found this response but it is from 2011 so I want to be sure this is still correct -
in the webassist/plugins/shopping_cart/checkout_form.php file, change:
/*if (empty($_SERVER['HTTPS'])) {
$testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
$c = curl_init();
curl_setopt($c, CURLOPT_URL, $testRedirect);
curl_setopt($c, CURLOPT_TIMEOUT, 90);
curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 1);
curl_setopt($c, CURLOPT_SSL_VERIFYHOST, 1);
$result = curl_exec($c);
if ($result) {
header("location: ".$testRedirect);
die();
yes, that should still be correct.
jo271221
Resolved - Thank You!
you're welcome.
jo271221
Just to clarify, the lines above simply need to be commented out as shown.
You can comment the lines or delete them, either way.
