Recordset not Available for E-Mail
Thread began 8/12/2014 5:54 am by Mike Perry | Last modified 8/12/2014 9:43 am by Jason Byrnes | 1632 views | 7 replies |
Mike Perry
I've had this issue before -- correcting it required adding the Recordsets to the page calling UE, and adding the 'global' statement to the required Recordset variables. I've tried the same here, but the e-mail doesn't include the requested data.
Both the calling page and the template are attached -- thanks. .
Mike
Think order of operations.
the code order on your page is:
* Create recordsets that look up the order info
* Store the order info to the database
* Send the email containing the order info using the recordsets
Since the recordsets are created before the information is saved to the databases, they are not returning a result.
you need to reorder the code so the recordsets come after saving the information to the database and before sending the email for them to work.
Mike Perry
A new set of eyes sure helps -- especially ridiculously simple problems like this.
A quick question -- can I "separate" all the functions into separate <?php ?> sections (recordsets, inserts, and the GetSQLValueString code) without causing problems? They get combined when behaviors are added, and it gets confusing rearranging them. . .
Thanks, Jason. . .
Yes, you can create separate code blocks for each function.
Mike Perry
One more --
I'm now getting double e-mails; first without the data, and a second one with it. Is there a way to delay triggering the e-mail transmission until after the page loads? Is there an "after page loads" trigger available?
Thanks,
ETA: Actually I'm getting phantom empty record inserts as well. No other "Insert Record" behaviors in the associated pages. . .
use the recordset not empty trigger, there is not an after page loads trigger that you could use.
Mike Perry
I think that cured it . .
Cool, glad to hear it is working.
