PowerCMS Installation Wizard Step 4 of 5
Thread begun 8/11/2014 12:53 pm by Paul | Last modified 7/31/2024 8:37 am by vered435903 | 2189 views | 5 replies |
Paul
I am stuck on PowerCMS Installation Wizard Step 4 of 5 and can't get past it.
There was a simulair ticket, but didn't contain much details of the issue.
I have checked my database name, checked privileges and settings.
Root mysql also didn't work so i'm still stuck with Step 4 of 5
Dreamweaver mysql connection test, passed.
Phpmysqladmin login test, passed
Any great suggestions?
try to manually create the tables in the database by using PHPMyADmin to run the install_cms/scripts/db.sql file.
of you get an error about tables already existing, delete any of the CMS tables before running the script.
Paul
Thanks for your fast reply. I have created a database, where can i find a list of tables and columns?
Paul
Yes, importing the install_cms/scripts/db.sql file from the root was the solution.
Thank you very much
glad to hear it is working.
vered435903
To anyone trying to add PowerCMS to their site in the 2020s or later.... Here's a helpful tip.
I have spent a lot of time trying to get past the step 4 of 5 (setting the admin login) and finally found the solution. It kept telling me that it couldn't save my information and to check my database connection. I have been trying all the solutions in these help forums, and here is what worked. Most of the forum answers are from long ago, before there was the MYSQLI option. Apparently PowerCMS was never updated for that connection so you need to use the classic MySql connection.
Here's the thread with the solution: https://www.webassist.com/forums/posts.php?id=41218
Here's Ray's comment from 2018 from that thread:
We debugged this in a screen sharing session. The issue was that a MySQLi connection was specified and PowerCMS has not been updated for MySQLi yet. We updated the connection to standard MySQL and the installer was able to complete.
Good luck!
