eCart 5 WA eCart Obj Share.js ajaxfile has no properties
Thread began 8/11/2014 11:28 am by eric284736 | Last modified 8/27/2014 9:20 am by Robert Crespo | 1754 views | 6 replies |
eric284736
Hi Jason,
I am trying to add a discount code to an existing site, but when I click on the OK button of the DISCOUNTS panel I get the following error:
At line 798 of file ..\Shared\Webassist\eCart\WA eCart Obj Share.js: ajaxfile has no properties.
I cleached the dat file and reset the layout, but that did not work. Any idea?
thx
Eric
here is an updated copy of the Shared\Webassist\eCart\WA eCart Obj Share.js file that should fix the error.
for help locating the users configuration folder, see this page:
WA eCart Obj Share.js.zip
eric284736
Thanks Jason!
you're welcome.
Robert Crespo
Tried the fix but it did not work
I added your new updated copy of WA eCart Obj Share.js but I am still getting the error message whenever I try to create a sale in eCart. Can you please address another alternative solution?
Thank you,
Robert Crespo
Delete the Dreamweaver Cache file from the users configuration folder:
Robert Crespo
Jason, that solved the problem. Once the Dreamweaver Cache file was deleted eCart started to function normally.
