Error
Thread begun 8/08/2014 9:20 am by Kumel | Last modified 8/14/2014 1:02 pm by Jason Byrnes | 2772 views | 7 replies |
Kumel
Error
I had created dataassist pages. Everything seem fine but when i wanted to add some extra field into the insert page a error pops up. file attached
This error appears after a add text field into the insert page & then from server behaviour panel as i choose insert record(existing) i receive that error. if i remove the text field then no error is shown.
What is the name of the text filed?
can you send a copy of the page that generates the error.
Kumel
attched* well i already deleted the macCache file or so. stil not working.
you didn't answer what the name of the text field is?
what text field did you add to start triggering the error?
I Need to know this in order to start troubleshooting.
Kumel
text field named: "TYPE" & "LENGTH"
type and length should not be used for field names as they are also javascript function names.
you should use different names for those fields like:
boat_type
or:
boat_lenght
Kumel
Thank You :)
you're welcome.
