show by date
Thread begun 8/07/2014 5:48 pm by Paul | Last modified 8/11/2014 3:18 pm by Jason Byrnes | 5874 views | 17 replies |
Paul
show by date
I have a MySQL database that is a list of events happening in the area. On the full list of events page, everything comes up fine.
What I am trying to do is show a few events on another page that start with todays date and go forward.
I have the mySQL "sort_date" field set as date. I found an old post on here that I edited the table fields:
SELECT * FROM events WHERE sort_date => NOW()
Seems like: NOW() is an old method.
Appreciate any assistance.
Here is the link to the page: http://www.conejo365.com/default2.php
1) For the comparison, => is not valid, it should be >= (Greater Than or Equal To, not Equal To or Greater Than)
2) you need to use Date_Format to format the date in the database and NOW() so they are in the same format:
WHERE DATE_FORMAT(sort_date, "%Y-%m-%d") >= Date_Format(Now(), "%Y-%m-%d")
Paul
Jason,
When I format the sort_date field as "date", the content in the fields come up as: 0000-00-00. I had to wipe the table and reimport the csv file.
This is what I put in the SQL section of the recordset:
SELECT * FROM events WHERE sort_date >= NOW()
I also don't understand what you meant with the NOW(). Where do I format that?
When I put this code in the SQL section, I get the error in the attachment. Here is line 1:
<?php require_once('Connections/connConejo.php'); ?>
Paul
your query now has 2 WHERE statements:
only use the one where statement:
that is what this part of the WHERE statement is doing:
Paul
Jason,
It tested with no records showing and when I uploaded the page, it was entirely blank. Nothing on the page at all.
Was I supposed to also format the sort_date field in phpmyadmin as date? But when I do that, it turns all the dates to zeros.
Paul
See PM
your sort date is in the wrong format in the Database. the datatype needs to be set to date, and the format should be:
yyyy-mm-dd
you are storing the dates in the wrong format:
7/30/2014
this means the column must a text column like varchar, MySQL can't do math operations like greater than or less than on text.
Paul
Jason,
I fixed the sort_date field to be yyyy-mm-dd and re-uploaded and replaced the entire database.
I then put in your code to the SQL statement of the recordset rsEvents:
When I click test, it shows it correctly. When I upload the page, it is completely blank.
Thoughts?
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
