Using Upload
Thread begun 8/07/2014 1:07 pm by randyrie405335 | Last modified 8/08/2014 12:45 pm by Jason Byrnes | 5641 views | 9 replies |
randyrie405335
Using Upload
How do I enter the file's name located by browsing into a MySQL database's field named "Filename"? I can get the file to upload but the file's name itself is not entered. Example: browsing locates /myfolder/my_file.pdf and the form successfully uploads the file to the myfolder directory but "my_file.pdf" filename is not entered from the form's file field "FileName" into the dB table's field "FileName" via the insert server behavior on the form.
What are the steps I need to take using the "File Manipulation: Upload Wizard" form to make this happen?
When you use the upload file server behaviors, a new binding group is greated in the bindings panel:
WA Uploaded File (File Field name)
where File Field name is the name of the file field.
this binding group contains the Server File Name biding which contains the name of the uplaoded file.
you need to use the Data Assist insert record behavior to insert the new record, and bind the file name column to the Server File Name binding.
see this tutorial for details:
http://www.webassist.com/tutorials/Add-file-fields-to-Data-Bridge-insert-update-pages
randyrie405335
Thanks Jason... your suggestions and the guide helped me to get this to work.
One other nag... how do I limit the filetype (extension) that can be uploaded i.e., I want to allow only PDF files to be uploaded and no other extensions?
The form works PERFECTLY on localhost. However, I've posted the webpage and uploaded the webassist folder to the production server but I'm surprised to get back a 500 error. I've checked the connection script (OK), checked for PHP errors in Dreamweaver (none found), checked the form for bad HTML or script errors (all OK) but still get a blank page. Permissions for the webassist folder and the upload webpage on the production server are OK. The MySQL database fields match the form's fields. So as far as I can find, all's well with the code and the build.
Didn't have this problem with two other websites I've built using Data Bridge so I'm sure I'm missing something obvious. Any ideas what other obvious areas I might check? (I'm including the page code in the Private Message.)
To limit the file types, use Server Validation. Select the File Extension validation type.
For the 500 error, add the following code at line 1 to turn on error reporting, this should return the actual error:
error_reporting(E_ALL);
once we know the real error, we can troubleshoot.
NOTE: in the future, pleases don't paste the page code in your message, instead, attach the php file.
randyrie405335
The error is:
Parse error: syntax error, unexpected '[' in /var/www/html/webassist/file_manipulation/helperphp.php on line 74
heres an updated version of the webassist/file_manipulation/helperphp.php file to correct the problem, this will be fixed in the next update.
randyrie405335
Replaced the helper.php file and am now getting this error:
Notice: Undefined index: WA_UploadResult1 in /var/www/html/seminars_spkrnominate_incl.php on line 13 Warning: move_uploaded_file(/var/www/html/078c7b66405d3292cc28d38d80fd3903_tmp.pdf): failed to open stream: Permission denied in /var/www/html/webassist/file_manipulation/helperphp.php on line 110 Warning: move_uploaded_file(): Unable to move '/tmp/phpeIrugI' to '/var/www/html/078c7b66405d3292cc28d38d80fd3903_tmp.pdf' in /var/www/html/webassist/file_manipulation/helperphp.php on line 110 Warning: copy(/var/www/html/078c7b66405d3292cc28d38d80fd3903_tmp.pdf): failed to open stream: No such file or directory in /var/www/html/webassist/file_manipulation/helperphp.php on line 112
With all the attempts to correct the first error, did I screw something up in my upload configuration?
for the first error, I need a copy of the seminars_spkrnominate_incl.php page.
the second error means that the permissions on the upload folder are not allowing write access, you need to edit the upload folder permissions to allow write access.
randyrie405335
OK. I'll check permissions.
in the upload file server behavior, you have set the upload folder to use the Server File Name binding, you need to select the upload folder.
