Country - State (Dropdown to Text Field)
Thread begun 8/07/2014 11:47 am by Art | Last modified 8/07/2014 1:59 pm by Art | 3425 views | 4 replies |
Art
I think this is true but it appears that the Checkout wizard produces a checkout page with Country/State selectors in which the state dropdown is replaced with a text box if non US countries are selected.
I ran the Insert form (checkout) wizard that just inserts a checkout form. However, this does not swap out the dropdown with a text field.
How can this be done?
This can only be done using the eCart Checkout wizard.
Run the eCart checkout wizard to create the checkout pages.
The Form Builder wizard will not create a checkout form that does this.
Art
The checkout page is working fine but I have a registration page that doesn't follow the same rules.
I found the javascript in the paymentoptions.js file and it seems like it should just work but it didn't.
Only the checkout form created by the checkout wizard will have this functionality
to add this functionality to other forms requires hand coding.
if you need help with the hand coding we can help through a premiere support appointment:
http://www.webassist.com/premier_request.php
Art
I think I figured it out...
