Alphabetizing our member database
Thread begun 8/06/2014 1:10 pm by gail.bergan407744 | Last modified 8/08/2014 12:47 pm by Jason Byrnes | 7058 views | 23 replies |
gail.bergan407744
I've built a list_users.php page using the old DW behaviors. I'm wondering if your MySQLi extension can do the same thing. In the attached file, you'll see that I have a clickable A-Z list; when our admins click on a letter of the alphabet, the resulting page gives a filtered list of members whose last names start with that letter. I looked at your pagination tutorial and I think I need something a bit more robust than that.
I have a new recordset called list_users_i.php using your extension, but there are still elements from the old behavior in the coding, such as lines 23-50, as well as my Show If and Repeat Regions behaviors. I realize these will need to be regenerated with your extension. My first question is, can you do an A-Z list? Second question is, which lines of that old code need to be axed?
In the recordset use the advanced editor and add another condition to the where clause:
AND (lastname LIKE paramLetter OR -1 = paramLetter2)
in the variables section, create 2 new variables as:
type: Begins with text
default value: -1
run time value: <?php echo(isset($_GET['letter'])?$_GET['letter']:""); ?>
type: integer
default value: -1
as for the code that needs to be removed from the page, you need to remove any code that relates to the old recordset.
gail.bergan407744
I'm sorry, I don't understand...what type of variable am I creating? Under Bindings, there is Form Variable, URL Variable, Session Variable, Cookie Variable, Server Variable, and Environment Variable.
Use the advanced recordset view, not the simple view.
In the advanced view, there is a section for variables to create the 2 variables that are needed.
gail.bergan407744
OK, I see what you mean. I've added the variables.
There is still apparently some coding errors (I am always pointed to line 28), but when I try to delete the line, it tells me it is rejecting the change. Do you see anything in the attached file?
By the way, I've replaced the Show If and Repeat Region with your scripts.
the code block at lines 14 - 28 does not have a closing php tag.
I think that code blank can be removed. it was for the original recordset.
gail.bergan407744
I know. But it won't let me delete those lines of code, or add the closing php tag. I've never seen that before.
dont know why it wouldn't let you, try opening the page using a text editor instead of Dreamweaver to remove the code.
gail.bergan407744
Well...the text editor let me delete the lines, but apparently some of them had something to do with my template. The display of the page in Design view is all off. (However it is correct in a browser).
But the more egregious problem is that the alphabetization is not working. It simply dumps our entire membership into the page; they are alphabetized to a point (when I originally set up the database) but then members added thereafter are all in a jumble. When I try to click on any of the A, B, C, ... links, I get No Records Found. Clearly this is not sorting correctly. See attached.
One thing I just noticed: when we made changes to the WHERE clause, DW created a whole new recordset called Recordset1. It still has those changes in my original listUser_i recordset, but now I have this additional one. Is this a problem?
when you deleted the code block, you also deleted the HTML tag line:
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/New_template_2010.dwt" codeOutsideHTMLIsLocked="false" -->
that should be added back
i dont see the additional recordset you mention on your page, only the listUsers_i recordset.
to troubleshot the listUsers_i recordset, add the following code in the body to write the SQL to the page:
<?php echo($listUsers_i->debugSQL()); ?>
