Multiple record updates on page with repeat region
Thread begun 8/04/2014 8:15 am by Blikbrein | Last modified 8/29/2014 11:42 am by Jason Byrnes | 6181 views | 14 replies |
Blikbrein
I am trying to update multiple checkboxes on the attached page. When I hit the submit button, I just get the rotating progress bar wheel and it stays stuck there. I'm really not sure where I went wrong on this one. Thanks in advance.
there is a blank line at line 1 of the file you attached. remove that.
if you continue to have a problem, I'll need to troubleshoot directly, see the private message section.
Blikbrein
See PM
There are 2 repeat selections around the checkboxes, there should only be 1. I would suggest recreating the page, and make sure only 1 repeat selection gets added around the checkboxes.
Blikbrein
I've done all of the above and still get the rotating circle on clicking update button. Could it be that my recordset and or multiple record update behaviour is incorrect? Please see file in PM section. Thanks!
see pm
Blikbrein
See PM
There is no server behavior on this page to process the form
add an update or insert or other server behavior to process the form and redirect to another page after it is complete.
Blikbrein
See PM
That code does not exist on the version of the page that on your server.
The copy of the instructors_Class_attendance.php page that is on the server does not have that server behavior on it.
