Installation problems with GoDaddy, I get just after the point were I am asked for admin details then I get errors
Thread began 8/03/2014 4:00 pm by itsnoonoo | Last modified 8/06/2014 7:51 am by Jason Byrnes | 2461 views | 8 replies |
itsnoonoo
Hi I had a similar problem and got a bit further using the database file supplied above, however I get as far as after the point were you choose the login and password for the administration, when I get the following error in the browser.
Warning: require_once(../images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /home/content/15/11939215/html/cms/WA_Globals/WA_Globals.php on line 59
Fatal error: require_once() [function.require]: Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/php5_3/lib/php') in /home/content/15/11939215/html/cms/WA_Globals/WA_Globals.php on line 59
itsnoonoo
Do you have any recommended hosting companies
Hi I noticed you have allot of problems with GoDaddy whom I host with, can you recommend a host in the UK
I am not to familiar with UK hosting services, maybe one of the other forum members will chime in, I use 1&1 hosting in the US and like there service, also Dreamhost is a good one.
itsnoonoo
The site is only a test site
http://www.njdixon.com/cms/index.php
Do hosts 1&1 host Web Assist products with little or no problems?
I Have not had problems with using 1&1 hosting.
itsnoonoo
1&1
Hi I found that 1&1 have a UK service to, before I change to them could you confirm that I should have less problems with them. I noticed in the forums that there are allot of problems with GoDaddy who i host with now. So will 1&1 be better for PowerCMS and PowerGallery?
itsnoonoo
Hi,as I said earlier when i set up PowerCMS there was problems with my installation. So I didn't get the admin login page address, could you please advise. Thanks for the info etc.
I Updated the cms/WA_Globals/WA_Globals.php and installed.php files to fix the problem.
