error on webassist/file_manipulation/helperphp.php on line 74
Thread begun 8/03/2014 2:09 am by jmuy76493762 | Last modified 10/16/2014 11:58 am by Jason Byrnes | 5859 views | 12 replies |
jmuy76493762
Hello
I work with data bridge 1.2 and all is ok but now for the first time i try to work with file manipulation upload I receive a message error.
I tried several times but still the same error ( error on line 74 in helperphp.php ).
Can you tell what i doing wrong.
I put the helperphp.php on attachment
Win7 and Dreamweaver 6
Thanks for cooperation
Best regards
what does the error say?
I cant troubleshoot an error without knowing what the error says.
jmuy76493762
Hello
When i upload my page to the server i receive the following error
Parse error: syntax error, unexpected '[' in /home/centreap/public_html/webassist/file_manipulation/helperphp.php on line 74
That's the code on my page
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../Video/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if($_SERVER["REQUEST_METHOD"] == "POST"){
WA_DFP_UploadFiles("WA_UploadResult1", "apasdevant", "0", "", "false", $WA_UploadResult1_Params);
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Upload Video</title>
</head>
<body>
<form method="post" enctype="multipart/form-data"><input name="apasdevant" type="file" id="apasdevant"></form>
</body>
</html>
Thanks alot
jmuy76493762
Hello
I delete my version 1.2 and put again the 1.18 and everything is going well now. I suppose there is a problem on version 1.2 and my system but i will come back for that later no time for the moment.
Thanks for coperation
Best regards
adrian214133
I am having the same issue. Do you know where I can download the older version from?
attached is an updated copy of the helperphp.php file to fix the problem.
jmuy76493762
Hello
Thanks alot it's working fine now with 1.2 version.
Best regards
jmuy76493762
Hello
I receive from Jason the upgrade for helperphp.php for version 1.2 and it's work very fine now
The file is in attachment
Bye
adrian214133
Thank you for your assistance.
The attachment works fine.
