Custom Shipping calculations Ecart
Thread begun 7/28/2014 7:09 am by birdscreen398247 | Last modified 8/07/2014 11:45 am by Jason Byrnes | 5041 views | 9 replies |
birdscreen398247
I want to determine shipping rates based on weight and the left three digits of the zipcode. Rather than writing shipping rules for every combination, is there a simpler way to refer to an array? What is the function to grab the left three digits of the zipcode and what code is needed to grab a result from an array? Can someone point me to some sample code for doing something like this?
use substr() to get the last 3 characters of a string:
$PostLast3 = substr($_POST["Postal_Code"], -3);
for arrays, see this page:
http://www.w3schools.com/php/php_arrays.asp
it should answer your question
birdscreen398247
Thanks, but I need the first three digits, not the last three.
The array tutorial looks like it will answer my questions on arrays.
ok, so use:
$PostFirst3 = substr($_POST["Postal_Code"], 0, 2);
also on w3schools is this page with details on the substr() function
http://www.w3schools.com/php/func_string_substr.asp
birdscreen398247
substr works, but can't get result from recordset.
I cannot get my result page to display a result from a recordset based on a substring from the previous page. I can display that substring on the results page and when I test the recordset, it gives me a correct result, but it won’t display on the page.
I have two pages: an input page and a results page.
The Input Page has a form with a field “zipcode”.
The results page has a form that displays a substring of zipcode and the result of a recordset.
The recordset (on the results page) is as follows:
$colname_rsZipZones = "-1";
if (isset($_GET['substr($_POST["zipcode"],0,3)'])) {
$colname_rsZipZones = $_GET['substr($_POST["zipcode"],0,3)'];
mysql_select_db($database_BirdScreen, $BirdScreen);
$query_rsZipZones = sprintf("SELECT * FROM zipzones WHERE ZIPSTART = %s", GetSQLValueString($colname_rsZipZones, "text"));
$rsZipZones = mysql_query($query_rsZipZones, $BirdScreen) or die(mysql_error());
$row_rsZipZones = mysql_fetch_assoc($rsZipZones);
$totalRows_rsZipZones = mysql_num_rows($rsZipZones);
I tried both a simple echo and also a text field. Both come up blank. (The echo of the substring works fine. It is the result from the recordset that does not display, although the "test" of the recordset works.)
<form name="form1" method="post" action="">
<p>Zip3: <?php echo substr($_POST["zipcode"],0,3); ?></p>
<p>
<input name="textfield" type="text" id="textfield" value="<?php echo $row_rsZipZones['ZONE']; ?>">
</p>
ZipZone: <?php echo $row_rsZipZones['ZONE']; ?>
</form>
What am I doing wrong? You can try the pages at http://www.birdscreen.com/TestSite/TestShipping.php
the code for the variable in the recordset is wrong:
which are you trying to use in the recordset? a URL variables or a POST variable, you cant use both which is what that code is trying to do.
birdscreen398247
Still doesn't work
I deleted the recordset and recreated it. I selected "Form Variable" instead of URL Variable.
It now looks like this:
if (isset($_POST['substr($_POST["zipcode"],0,3)'])) {
$colname_rsZipZones = $_POST['substr($_POST["zipcode"],0,3)'];
It still comes up blank.
substr is inside the post variable name:
using the simple recordset interface, you cannot use functions like this, yu can only enter the variable name.
set it to use a URL variable named zipcode.
then add code before the recordset to set the URL variable:
<?php if(isset($_POST["zipcode"])) $_GET['zipcode'] = substr($_POST["zipcode"],0,3); ?>
birdscreen398247
Thanks. That worked.
you're welcome.
