eCart not creating receipt email.
Thread begun 7/24/2014 11:55 pm by jimsg4 | Last modified 7/25/2014 11:34 am by Jason Byrnes | 3513 views | 6 replies |
jimsg4
Hi, I just purchased the Super suite, and for the past 4 days I have been trying to get eCart to send an email receipt. I am not using a payment gateway, I am just trying to send an email receipt when a product is ordered. For reference, I setup a contact form and the email including CC and Bcc worked fine. I setup the eCart email config settings with same info as the contact form, but cannot get it to even insert a record in the email_log table let alone send an email.
The contact form inserts a record into the email_log table, but when I check out, I get nothing. No log, no email, nothing. It's as if it's not being triggered when I click the submit button on the confirm page. The order shows as successful, but again no email activity at all.
I checked to make sure the UE Server Behavior on the confirm page is set to Button: Payment_submit pressed, but it makes no difference.
I have uninstalled and reinstalled both DB and eCart several times as well as deleting the DW cache. I get a lot of DW crashes when using WA in both CS4 and CS6. I can be right in the middle of setting up Data Assist or eCart pages and DW will just crash in both versions.
I'm about at my wits end. Any help would be much appreciated.
Thanks,
Mac OS X Lion, DW CS4 and CS6
jimsg4
UPDATE!
I changed the trigger in the UE Server Behavior to "any form post" and the email gets sent when clicking the Continue button on the checkout.php page, but it sends the email again when clicking the Complete Order button. I can also get the email to send by changing the trigger in the UE Server Behavior to "eCart: my eCart Object is empty" then hit the back button after completing the order. BUT, it still will not work with the trigger set to "Button: Payment_submit pressed", which is what I need.
jimsg4
Info
Hi Jason,
See PM.
on the confirm page, the store order details behavior had the redirect to the success page sent, this redirect was happening before the email could be sent. i moved the redirect from the store details behavior to the email behavior to fix the problem.
jimsg4
Thank You!
Thank you Jason. I saw that, but it was there when the page was created Over and over again, so I didn't pay it much mind. I appreciate the quick response. I would go comb my hair if I had any left. ;-) Again, Thank You!
You're welcome.
