Display database statistics without multiple recordsets
Thread begun 7/23/2014 10:39 am by Dennis | Last modified 8/12/2014 2:30 pm by Dennis | 3741 views | 7 replies |
Dennis
I created a page to show database statistics from a single table. Example total records from dues paid column containing 2014. As I knew no other way, I used $totalRows from a recordset to get this information. This worked well. The problem is I keep getting new ideas of statistics to list so now I have many, many recordsets in the page, which I have to believe is not a good idea.
How else can this be done? Also since I will probably recreate the page, can this be done with the MySQLi Server Behaviors
Thanks,
Dennis
you can use count() and sum() and other math functions in the SQL statement and add an alias, for example:
SELECT COUNT(idColumnNAme) as recordCount, SUM(priceColumn) as totalPrice FROM tableName
yes, this can be done in MySQLi recordsets also.
details on SUM and other aggregate functions can be found here:
http://www.tizag.com/mysqlTutorial/mysqlsum.php
Dennis
Thanks Jason,
Things came up and I haven't had a chance to work with your suggestions yet, but I did want to thank you for them.
Dennis
Dennis
Jason,
Thanks again for you suggestion, the COUNT function looks very useful. I wonder if you could help me further...
Not understanding the concept of recordsets, I never know how to follow/use tutorials or examples that refer to SELECT statements. Are they always used inside a recordset? Or can they also be coded into the page?
I have a Dynamic MySQLi connection setup "connDennis_i"
What code would I enter to use this connection?
And using the COUNT part of the example you show above, "SELECT COUNT(idColumnNAme) as recordCount FROM tableName"
What code would I enter to use this SELECT statement?
And how would I echo the result?
Thanks,
Dennis
Yes, select statements are always used in recordsets.
to use the connection you created, you should create a recordsety that uses that connection, that will generate the code to use your connection.
in the recordset, go to advanced view, and enter the SQL statement:
where idColumnNAme is the name of the ID column in your table and tableName is the name of the table.
to echo the result to the page, open the bindings panel, expand the recordset, and add the column binding to your page from the recordset
Dennis
Thanks Jason, for clearing that up for me. I've wondered about that for some time.
The link you suggested above http://www.tizag.com/mysqlTutorial/mysqlsum.php (ps, they have very good tutorails) has the following example that I'm trying to understand how to use...
// Make a MySQL Connection
$query = "SELECT type, SUM(price) FROM products GROUP BY type";
$result = mysql_query($query) or die(mysql_error());
// Print out result
while($row = mysql_fetch_array($result)){
echo "Total ". $row['type']. " = $". $row['SUM(price)'];
echo "<br />";
Would I put the "SELECT type, SUM(price) FROM products GROUP BY type" in a recordset and then hand code everything under it?
Also, if COUNT & SUM are used in a recordset, how does that help my dilemma of having to many recordsets? Is it because they provide many more results (statistics) with a single recordset?
Because I want to pick & choose what statistics I display, I went searching for a way to stack COUNT statements, I came across this example of code on stackoverflow. but I was able to get it to work (in a recordset) and echo the aliases...
SELECT
SUM(CASE WHEN Mbr_Status = 'Regular' THEN 1 ELSE 0 END) StatusRegular,
SUM(CASE WHEN Mbr_Status = 'App' THEN 1 ELSE 0 END) StatusApplicant,
SUM(CASE WHEN Mbr_Status = 'None' THEN 1 ELSE 0 END) StatusNone,
SUM(CASE WHEN Mbr_Status = 'Club' THEN 1 ELSE 0 END) StatusClub
FROM member_accounts
Does this look like a good (reliable & efficient) statement? I'm asking because I don't have a clue as to what it is doing with the if statements.
create a recordset using the following SQL:
SELECT type, SUM(price) AS priceSum FROM products GROUP BY type
dont forget to add an alias SUM(price) AS priceSum
then use the bindings panel to echo the information to the page and a repeat region if the recordset returns more than one row.
because you are creating one recordset to return the results that you had been trying to get using multiple recordsets.
this:
SELECT
looks OK, except for the fact that the alias's are missing the ass statement.
If you need more help in createing this, i would sugest signing up for a premiere support appointment:
http://www.webassist.com/premier_request.php
Dennis
Thanks Jason, you have been very helpful and I appreciate it.
Dennis
