Dynamic Dropdown values for Update page
Thread begun 7/21/2014 9:43 am by iainmacdonald331081 | Last modified 7/23/2014 11:55 am by Jason Byrnes | 7718 views | 18 replies |
iainmacdonald331081
This is the last thing I haven't quite got with the dynamic drop downs. Basically to get them to work and how the current values for a record on the update page.
I've attached the file, and added some details below.
iainmacdonald331081
More info
you need to use the Set Selected In List behavior to set the parent using list using the corresponding column from the WADAlodges recordset on the body tags on load event
also add the Populate list from array behavior to the onload event to populate the child list and another instance of the set selected behavior to set the child list.
iainmacdonald331081
Thanks Jason - I have added the Set Selected In List behaviour, but only to the Continent field from the WADAlodges recordset. How do I apply / make use of any On Load event on the body tag?
See screenshot.
select the body tag in the tag selector when you add the set selected behavior and select the onload event.
iainmacdonald331081
Sorry Jason - I'm not getting this.
I tried that, and have the line:
<body onLoad="WA_setSelectionsInChildList(MM_findObj('Parent'),<?php echo $row_WADAlodges['Continent']; ?>)">
But still not showing the current value.
iainmacdonald331081
Thanks Jason.
Details below.
in the onload event, you are using a column named Category:
onload="WA_setSelectionsInChildList(MM_findObj('Parent'),<?php echo $row_WADAnominations['Category']; ?>)"
using var_dump to write the contents of the WADAnominations recordset, i do not see a column being returned named Category. I see a column named CategoriesFullID, is that the one that should be used?
looks like it, if i change it to:
onload="WA_setSelectionsInChildList(MM_findObj('Parent'),<?php echo $row_WADAnominations['CategoriesFullID']; ?>)"
on load selects the Best Walking Safari form the category
iainmacdonald331081
Thanks Jason - sorry I missed that - I've been changing the data structure quite a bit with all this, breaking them out into continents and countries, and having them separate, when they used to be part of the category.
All looks like its working, and also with the short name, so thanks you for spotting that.
I did notice one other odd thing - if you search the site for 'Zarafa Camp' which has a lot of nominations over a few years, the year drop down in the update page isn't always showing the correct year.
It looks like its OK for 2015 and 2014, but all the others are showing 2008.
