Multiple Errors on create DA pages
Thread begun 7/21/2014 9:01 am by Brendan | Last modified 7/22/2014 7:21 am by Jason Byrnes | 2055 views | 3 replies |
Brendan
I have run the wizard a few times, and am getting different errors.
First I tried using a preset that I had already configured and used previously, but when I ran the wizard I got the JS error regarding "col has no properties", which usually coincides with using a stock preset on a custom db.
So, I tried using the "new from blank" preset, created my search and results pages, and then tried to create a preset - got the same error
Now, I tried "new from blank", and not creating a preset, and i'm getting an error "newDOM has no properties"
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
Brendan
Jason,
I found those suggestions in another thread as well. I reset the workspace, closed dreamweaver, deleted the cache, and then reopened dreamweaver.
are you still getting the errors?
Double check that the database connection is working.
Also, when using your preset, make sure to select the table the preset was created for, or select the option to have the table created.
