wrong syntax
Thread begun 7/21/2014 2:41 am by Jamie | Last modified 7/21/2014 8:46 am by Jamie | 3214 views | 4 replies |
Jamie
wrong syntax
Hey Jason
Am trying to use the data stored in the db to add the year from the relevant column but clearly am using the wrong syntax but not sure how it should be structured
This is what I am using
$copyYear = <?php echo($GlobalSettings->getColumnVal("copyright_startyear")); ?>;
How should I structure it please?
Many thanks
Jamie
use to write the copyright_startyear column to the page.:
Jamie
Sorry, I should have added the full code snippet for context
<div id="copyright">&copy; <?php
$copyYear = 2014;
$curYear = date('Y');
echo $copyYear . (($copyYear != $curYear) ? ' - ' . $curYear : '');
?> <?php echo($GlobalSettings->getColumnVal("CompanyName")); ?><br>All Rights Reserved.</div>
Where 2014 is I want to be able to change it through the DB but if I use $copyYear = <?php echo($GlobalSettings->getColumnVal("copyright_startyear")); ?>; I get a syntax error
Jamie
you cant use php tags nor the echo statement when setting a variable value
$copyYear = $GlobalSettings->getColumnVal("copyright_startyear");
Jamie
Brilliant. Thanks Jason
