If / Then statements within Add Cart Code
Thread begun 7/15/2014 12:48 pm by dDog | Last modified 7/15/2014 2:09 pm by Jason Byrnes | 2367 views | 5 replies |
dDog
I'm attempting to modify the AddToCart code, so the dynamic pricing from the recordset is entered based on user. What am I missing?
See lines 74-127 I'm using If / Then statements, but something is going wrong.
I thank you in advance, many times over.
I'm not seeing an if / else statement in the code section you specify?
dDog
Wrong file... oops.
I'm attaching the correct file.
The if statement uses a recordset that is not defined till line 329.
move the templateDisplayName recordset so that is comes before the add to cart code.
dDog
Awesome!!!
I moved the recordset up and now it works. Thanks!!!
you're welcome.
