$_SERVER["SERVER_NAME"] sometimes not equal to the $_SERVER["HTTP_HOST"]
Thread began 7/12/2014 9:44 am by Colin | Last modified 7/16/2014 8:59 pm by Colin | 4061 views | 5 replies |
Colin
[suggestion] $_SERVER["SERVER_NAME"] sometimes not equal to the $_SERVER["HTTP_HOST"]
well...
when I use the login method
http://www.littlebau.com/server_name.gif
it use this Predicates
strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0)
[in Usually case]
the "HTTP_REFERER" 's dmain name is equal to the "SERVER_NAME"
[but in sometimes,They are not equal]
for example about that
http://www.littlebau.com/server_name2.gif
that you can see my port is 8086,so in this situation,the "strpos" method will never greater than 0,no value
solution 1,add the "SERVER_PORT"
strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].':'.$_SERVER["SERVER_PORT"].$_SERVER["PHP_SELF"])) > 0)
solution 2,Replace to "HTTP_HOST"
strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["HTTP_HOST"].$_SERVER["PHP_SELF"])) > 0)
I think solution 2 more better and easy to fix
Colin
is there anything unclear ?
because of no any feedback...
In the case where the server name and http post are not the same, you wont be able to use the Current Page Submit trigger, use the Any Form Post trigger or the Button Submit pressed trigger instead.
Colin
Hi Jason
although the "Any Form" and "Button" trigger can solve the problem
but I think the "Any Form" and "Button" trigger could be a dangerous behavior
because of the "hack" hehavior will cause damage if somebody know your .php Receive data page address
The Current page submit trigger problem you are having boils down to a server configuration issue.
in your case, the server is configured in such a way that the Current Page Submit trigger wont work.
In this case, you have 2 options:
- Fix the server configuration so that the Current page submit trigger can work,
- Use a different trigger
Colin
well...
got it and thanks~
