Styles (bold vs not bold)
Thread begun 8/24/2009 6:49 am by web364946 | Last modified 8/25/2009 9:56 am by web364946 | 2591 views | 4 replies |
web364946
I have a small problem with the program - whenever I try to add text it shows up as bold. Even when I try to mark some text as not bold and some as bold, it all shows up the same.
Has anyone encountered the same problem, and how do I solve it?
is the a CSS rule that is overriding the bold setting?
Please post a URL where I could see the problem to look into the cause.
web364946
Url
decleor_offer.php
Thanks!
This is because you have your content in <th> tags instead of <td> tags. Table headers are automatically bolded. You can override it in the css by setting the font-weight to normal in a subtag or you can use the <td> tag instead of the <th> tag to fix the problem.
web364946
so simple when you know how :-) Thanks a million!
