When installing xampp the command prompt that popped up was empty.
Is this going to pose a problem later?
Imposible to say one way or the other, really. It may or it may not, only time can answer that question.
If you have XAMPP install questions, You should visit the apache friends forum for help:
https://community.apachefriends.org/f/
I guess we will cross that bridge if I problem arrives.
I was just checking to see if this was a common problem and if anyone had a solution because they've encountered it.
