Dynamic Dropdown - Dynamic Array
Thread begun 7/09/2014 1:08 pm by tn228553 | Last modified 7/10/2014 12:29 pm by Jason Byrnes | 3100 views | 5 replies |
tn228553
I'm following the tutorial for using Dynamic Dropdowns and the Primary dropdown is showing up empty. Attached is a sample .php page and .sql of the data.
Basically I want to Display the column Division in the first dropdown and then auto-populate the second dropdown with column AreaName where Division is equal to what was selected in the Division dropdown.
Seems pretty straightforward but I guess I'm missing something.
First, before the first select list, add the the following code to set the recordset to the first record:
$rows = mysql_num_rows($Recordset1);
if($rows > 0) {
mysql_data_seek($Recordset1, 0);
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
then select the first list, and add the Populate List from Array behaivor.
open the behaviors window:
Window -> Behaviors
NOTE: Behaviors, not Server Behaviors
click the plus button and go to WebAssist -> Dynamic Dropdowns -> Populate List from Array
tn228553
Missing Something
Please view updated private .php
it is working for me when I test your file.
when i select R from the parent list, it populates the child list with Collier, whhen I select V, it popualtes the child list with Charlotte
tn228553
Works!
Oh geez, must have been cached...works great! Thanks for the help as always Jason, really appreciate it.
you're welcome.
