hide record based on date
Thread begun 7/09/2014 3:24 am by Jamie | Last modified 7/09/2014 9:51 am by Jason Byrnes | 4219 views | 7 replies |
Jamie
Hey Jason
I have been using this thread as a reference.
What I have is a list of presentations that are made at a bi-weekly networking group. The list is sorted by PresentationDate ASC and I want the topmost record to becom hidden the day after the meeting it is relevant to (eg if the meeting was today 9 July then I would want to the topmost record to become hidden on 10 July)
Basically, I have set the rules manager as per that referenced thread and named the rule 'HideDate' and bound the 'compare to' to the column PresentationDate in the db but this hides all records in the list rather than just the topmost.
I am thinking at this point that the show if route is not the way to go and that it would need something in the recordset itself to achieve what I am trying to do.... just not sure how?!
I have attached the files
Many thanks
Jamie
Since you arew using a dynamic date, the security assist show region wont work.
you can add a where clause in the SQL to do this though:
WHERE DATE_FORMAT(DateColumn, "%Y-%m-%d") < (CURDATE() + INTERVAL 1 DAY)
where DateColumn is the name of the date column in the table.
Jamie
thanks Jason I thought that would be the case...
I have added that to the recordset and get the following error: Parse error: syntax error, unexpected '%' in /home/blandfft/public_html/meeting-info.php on line 96
Also, how would I incorporate that to SELECT *, member_info.* FROM presentations INNER JOIN member_info ON MemberNameID = MemberID WHERE Live = 1 ORDER BY PresentationDate ASC ?
"I have added that to the recordset and get the following error: Parse error: syntax error, unexpected '%' in /home/blandfft/public_html/meeting-info.php on line 96"
i would need to see the code
"Also, how would I incorporate that to SELECT *, member_info.* FROM presentations INNER JOIN member_info ON MemberNameID = MemberID WHERE Live = 1 ORDER BY PresentationDate ASC ?"
WHERE Live = 1 AND DATE_FORMAT(DateColumn, "%Y-%m-%d") < (CURDATE() + INTERVAL 1 DAY)
Jamie
thanks thats what I thought... have added the file to the PM area
use single quotes instead of double in the date format:
DATE_FORMAT(DateColumn, '%Y-%m-%d') < (CURDATE() + INTERVAL 1 DAY)
Jamie
brilliant. many thanks Jason
you're welcome.
