I have your sqli extension --- can I do an insert or update and not have it refresh the page - if so -- how?
Thread began 7/07/2014 6:15 pm by jim.young353872 | Last modified 7/08/2014 2:24 pm by Jason Byrnes | 1541 views | 3 replies |
jim.young353872
I want to insert a record but not have it refresh the page. Even though I leave the "go to" blank it still is refreshing the page. Any thoughts.
It is posible to this, but would require hand coding that is not supported.
you would need to use jquery and ajax to perform the update asynchronously.
jim.young353872
Insert a record without refreshing the page.
I have a page that shows an Table with data that is populated using jquery and ajax. I want to know if I can use the Webassist extension to enter/insert a record but not have it refresh the page. I was hoping to write some javascript that when I insert a new record (using webassist extension) I would trigger the update of the table. I hope that makes sense. That is the reason I was trying to find out if I can stop the entire page from refreshing when I use your insert.
Yes, it is possible to do this, but takes hand coding to have the form submit using ajax. If you need help congfiguring the ajax submit, we can help in a premise support apointment:
http://www.webassist.com/premier_request.php
