mySQLi Repeat Region, how to do a nested Repeat Region?
Thread begun 7/07/2014 3:56 pm by Steve | Last modified 7/08/2014 9:55 am by Steve | 4404 views | 2 replies |
Steve
Possible?
Got a region that first selects ParentId and Title then sets an ID veriable to use in a sub query to select all Sibilngs (the usual stuff...).
while(!$rsParent->atEnd()) {
<strong><?php echo($rsParent->getColumnVal("typeName")); ?></strong><br />
<?php $subtarget = ($rsParent->getColumnVal("typeId"));
echo 'subtarget : ' .$subtarget; ?>
<br />
$rsSiblings = new WA_MySQLi_RS("rsSiblings",$rtk_i,1);
$rsSiblings->setQuery("SELECT tblinvtype.typeId, tblinvtype.typeName FROM tblinvtype WHERE tblinvtype.`typeSibling` = ?");
$rsSiblings->bindParam("i", "".$subtarget ."", "75"); //target
$rsSiblings->execute();
<ul>
while(!$rsSiblings->atEnd()) {
<li><a href=#"><?php echo($rsSiblings->getColumnVal("typeName")); ?></a></li>
$rsSiblings->moveNext();
</ul>
$rsParent->moveNext();
CraigRBeta Tester
Don't know if this helps, but a while ago, I read about creating a 'nested' repeat with a single recordset. - and I use this technique quite a bit.
Unfortunately I can't find the link to the article, so I dug up an old example and updated it to work with mysqli
The technique is to order the recordset by the 'parent' and then use a php if block to display the parent if it is different to the previous row, otherwise put a non breaking space.
It works fine in a table, you may be able to use the same logic
eg
<?php $previous = "";?>
<table>
<tr>
<th>Parent</th>
<th>Child</th>
</tr>
while(!$Recordset1->atEnd()) {
<tr>
<td>
// display field if it doesn't match previous value
if ($Recordset1->getColumnVal("Parent") != $previous) {
echo $Recordset1->getColumnVal("Parent"); ?>
} else {
// otherwise, insert a non-breaking space
echo '&nbsp;';
// set $previous to current value for next time
$previous = $Recordset1->getColumnVal("Parent");
<td>
<td><?php echo($Recordset1->getColumnVal("Child")); ?>
<td>
$Recordset1->moveNext();
$Recordset1->moveFirst(); //return RS to first record
</tr>
</table>
Steve
Thanks CraigR,
I can loop a recordset AND use an inner var using this method:
$sql="SELECT tblinvtype.typeId, tblinvtype.typeName FROM tblinvtype WHERE tblinvtype.`typeSibling` = ?";
echo $subtarget = ($rsParent->getColumnVal("typeId"));
/* Prepare statement */
$stmt = $rtk_i->prepare($sql);
if($stmt === false) {
trigger_error('Wrong SQL: ' . $sql . ' Error: ' . $rtk_i->error, E_USER_ERROR);
/* Bind parameters. TYpes: s = string, i = integer, d = double, b = blob */
$stmt->bind_param('i',$subtarget);
/* Execute statement */
$stmt->execute();
$stmt->bind_result($typeId, $typeName);
while ($stmt->etch()) {
echo $typeId. ', ' . $typeName . '<br>';
Referenced in this article:
http://www.pontikis.net/blog/how-to-use-php-improved-mysqli-extension-and-why-you-should
