Date Picker not working with two forms on page
Thread begun 7/07/2014 8:25 am by info4753 | Last modified 7/15/2014 11:31 am by Jason Byrnes | 6740 views | 23 replies |
info4753
I have a page with two forms that insert into the same database table (one for standard Monitor size and one for mobile). If I add both forms via framework, the datepicker will not work.
How can I solve this problem? Thanks for any help.
The JQuery validation is also not working.
make sure that both forms use unique names for the forms and for all the elements in them.
if you still have problems, I'll need to troubleshoot directly, see the private message section.
info4753
Thx Jason. Do the fields also have to be unique or just the form?
"and for all the elements in them."
Yes, the form element names need to be unique also
info4753
The JQuery validation works now but not the date picker. Please see the pvt section for the connection data. Thanks Jason.
there are conflicting jquery versions on the page.
on the main page, you include jquery:
<script type="text/javascript" src="../ScriptLibrary/jquery-latest.pack.js"></script>
<script type="text/javascript" src="../js/jquery-ui.min.js"></script>
then each of the plugin pages include jquery again:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js">
</script><script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
the jquery scripts can only be added to the page once, you will need to remove the other jquery script referances.
info4753
This post has been deleted.
info4753
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
Is being inserted twice by your extension.
I've removed them all ind both form pages but now even the JQueryValidation is not working anymore...
I Updated the member insert file to fix the issue.
info4753
Thx Jason. What did you change?
