Error message with simple MySQLi page
Thread begun 7/04/2014 10:49 am by msummers194171 | Last modified 9/26/2014 12:45 pm by Jason Byrnes | 6276 views | 7 replies |
msummers194171
I've recently installed the MySQLi extension and am just making a simple page. My page looks like this -
ini_set('display_errors', 1); ?>
<?php require_once('Connections/connMySQLi.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$rsQuotes = new WA_MySQLi_RS("rsQuotes",$connMySQLi,10);
$rsQuotes->setQuery("SELECT quotes.quotes_quote FROM quotes WHERE quotes.quotes_display=1");
$rsQuotes->execute();
<!doctype html>
<html>
<head>
<meta charset="utf-8">
</head>
<body>
while(!$rsQuotes->atEnd()) {
<p><?php echo($rsQuotes->getColumnVal("quotes_quote")); ?></p><br>
$rsQuotes->moveNext();
</body>
</html>
My Connection file looks like this (and it tests OK, as does the recordset on the simple page) -
# FileName="WADYN_MYSQLI_CONN.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_connMySQLi = "123.123.123.123";
$database_connMySQLi = "database";
$username_connMySQLi = "user";
$password_connMySQLi = "password";
@session_start();
$foundConnection = false;
if ($foundConnection == false) {
$domains = explode(",","example.com");
for ($domindex = 0; $domindex<sizeof($domains) && !$foundConnection; $domindex++) {
$domainCheck = trim($domains[$domindex]);
if (strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) !== false && ($domainCheck == "" || strpos(strtolower($_SERVER["SERVER_NAME"]),strtolower($domainCheck)) == strlen($_SERVER["SERVER_NAME"])-strlen($domainCheck))) {
$hostname_connMySQLi = "localhost";
$foundConnection = true;
$connMySQLi = new mysqli($hostname_connMySQLi, $username_connMySQLi, $password_connMySQLi, $database_connMySQLi);
(The code has been 'sanitized')
When I upload these files and browse to the page, I get this error -
Fatal error: Allowed memory size of 104857600 bytes exhausted (tried to allocate 4294967296 bytes) in /home/example/public_html/webassist/mysqli/rsobj.php(224) : eval()'d code on line 1
Any idea why I am getting that?
Jamie
Not sure if the same, but check out this thread http://www.webassist.com/forums/posts.php?id=34751
Hope it helps
Jamie
msummers194171
Thanks, Jamie - I'll see if that has any effect, although I am skeptical. What I'm trying to do is simply retrieve 20 or so paragraphs of content and display them in a repeat region.
It is curious that the error messages are pretty much the same though...
tom113673
I came across this problem too. The solution was to make some changes to the MySQL table concerned. I had some fields defined as MEDIUMTEXT when TEXT would have been sufficient (and more efficient); changing them to TEXT fixed the problem.
There was no problem using the original table with the mysql extensions as opposed to the mysqli extensions. I suspect it's to do with PHP's mysqli extensions rather than the new DW extension.
msummers194171
Tom - thanks! That was it. Who would have thought to make that change? In my case I had a field defined as longtext and when I changed it to just text, the process worked without error.
tom113673
I'm glad I could help.
markhaynes75235
MySQLi and LONGTEXT Data Type
I ran into a similar problem this week using the MySQLi extension. Whenever my recordset returned data from a field that was defined as LONGTEXT data type, the data showed up in part in the Recordset dialog's Test window but nothing would appear on the page or in live preview. Fortunately for me, changing those fields to TEXT datatype worked since none of them exceeded 65,535 characters.
I did some further research and came across this article in Stackoverflow which might help others:
http://stackoverflow.com/questions/10335278/prepared-mysqli-select-statement-on-longtext-field-is-coming-back-empty
Perhaps Ray's team can add some code that checks to see if the field being queried is of type LONGTEXT or MEDIUMTEXT and if this is true, the necessary Store Results can be added.
Thanks Mark, i have forwarded this information to Ray and logged a bug so it can be corrected in the next update.
