MySQLi - What are the new methods we need to use?
Thread begun 7/03/2014 10:43 am by Steve | Last modified 7/07/2014 9:02 am by Jason Byrnes | 7393 views | 12 replies |
Steve
Is there a list or some reference on how to use the new record set values when hand coding?
for instance:
if (isset($rscoupons->getColumnVal("id"))) {
do something
This does not work. So it seems there are a number of things we will need to learn to adapt to the new methods. Are there any examples for a smooth migration?
what is it you are trying to do with this?
you wouldn't use isset for this with a standard recordset or with mySQLi.
Steve
Jason,
just trying to use isset like with any other recordset value. For instance IF there is a value present (existing in a recordset) then do something.
In the actual case I am submitting a coupon code and IF it is valid (value sent to SQL query creating a recordset with the resulting ID) I show a region, if not show other region.
Can we not use isset with MySQLi record sets?
in this case use the Recordset is empty / is not empty behaviors.
Steve
So there is are a number of php functions that don't work with mySQLi recordsets?
I tried this one also (not empty) and it also failed:
if (!empty($rscoupons->getColumnVal("id"))) {
Please let me know so I don't spend a bunch of time thinking it's my syntax that is off
http://www.php.net/manual/en/function.empty.php
http://www.php.net/manual/en/function.isset.php
there are server behaviors for this in the MySQLi server behaviors:
WebAssist -> MySQLi -> Show Region
Show Region if Recordset is Empty
Show Region if Recordset is Not Empty
Steve
ok, thanks for that, but also people should be aware that there are missing features in the new mySQLi generated record sets when compared to recordsets created in the prior version.
isset and empty can't be applied directly to a recordset variable.
Hopefully WebAssist sorts this in the future as there are many of us that don't just use behaviors but rather appreciate web assist extensions for rapid development / prototyping while still writing our own code for more unique conditions.
As a tip to others that are running into this problem, you can use a recordset value assigned to your own variable.
For instance:
<?php $id = $rscoupons->getColumnVal("id"); ?>
if (!empty($id)) {
these aren't missing features, isset and empty shouldn't be used for regular MySQL recordsets either.
There are Corresponding show if behaviors for Is Empty / Is not empty for standard recordsets also.
you may have been able to get isset and empty to work with standard MySQL recordsets, but that is not the proper way for determining if they are empty or not.
the proper way to determine if a recordset is empty or not is to look at the number of rows returned. if it returns 0:
$RecordsetName->TotalRows == 0
it is empty.
Steve
yes, $RecordsetName->TotalRows == 0 makes logical sense for determining if a recordset with values was generated.
But what about recordset values being present or not?
For instance you have 3 recordset values and one of the three not always populates since it's an optional item.
In this case we would use the isset(recordset['name']) to do something if present or something else if not present.
Is there a way to do that with mySQLi record sets without using a behavior? I would expect that we would use the bindings to determine the values name (drag from bindings to generate an echo value) then apply a isset or other php function like empty.
