Coupon codes: I need to track which coupon is used.
Thread begun 7/03/2014 9:55 am by Patrice | Last modified 7/29/2014 4:54 pm by Patrice | 4070 views | 18 replies |
PatriceWebAssist
Using eCart. Coupons work great. No problems with the math.
New client request: To capture which coupon is being used with which purchase. I assume, first add another field to the db. And redo the order results so client can see which coupon code goes with which order.
But then, I'm stumped. I need to tie the entry to the database. Since the cart.php shows in bindings, after I add a coupon field to the database, I assuming I can tie it but then what happens to the math?
I don't want to break the existing cart by doing this wrong. Does this need a premier ticket?
UPDATED: client just added a request to do this with PowerStore also, on two sites.
" Does this need a premier ticket?"
Yes, this will need a premiere support appointment to accomplish.
PatriceWebAssist
OK… will one ticket take care of eCart and PS? or do I need 2 tickets?
One ticket can be used for both, but it may take multiple sessions.
PatriceWebAssist
Great. I'll gather log in etc, and open a ticket.
Thanks Jason.
you're welcome.
PatriceWebAssist
See PM for details; will open a ticket in a minute.
You don't post any Premiere info here, submit the request using the form:
http://www.webassist.com/premier_request.php
you dont need to include server info in the premiere request, just provide the details of what you want to accomplish and ray will contact you to schedule the appointment.
PatriceWebAssist
See PM
the screen sharing is a part of Premiere support.
