Error in editing design on store I moved
Thread begun 7/03/2014 6:49 am by jo271221 | Last modified 8/11/2014 3:12 pm by Jason Byrnes | 5107 views | 7 replies |
jo271221
I am moving the store halloweranch.com to sharinhall.com I got this error prior to change any on the plug
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/sharinha/public_html/store/webassist/plugins/styler/styler.php on line 92
Fatal error: Call to a member function asXML() on a non-object in /home/sharinha/public_html/store/webassist/plugins/styler/styler.php on line 105
I have attached the user, ftp and store admin
try deleting the themes/temp_editing folder on the server to have it recreated.
jo271221
Design Issue
Thanks for the prompt reply. That did not work. I only need it to replace the logo. Is there another way to edit the logo? I want the logo to NOT have the name logoshiny therefore I do not want to simply replace that image. Thank You!
you can edit the logo in the source code.
in the webassist/themes folder, open the folder for your selected theme. then go to templates/index.dwt.php to edit the logo image:
<img id="headerLogo" alt="logo" src="../../../../images/logo.shiny.png">
jo271221
The edit theme stopped working on another site.
The design Editor needs to have extended permissions on the theme folder in order to create the temp editing folder.
i updated the permissions for webassist/themes folder to allow for creating the temp editing folder and files under it
jo271221
Thank You!
you're welcome.
