Update Record server behavior issues
Thread begun 7/02/2014 12:50 pm by gail.bergan407744 | Last modified 7/07/2014 9:02 am by Jason Byrnes | 7683 views | 21 replies |
gail.bergan407744
I've uploaded a page at www.gcssepm.org/update_self2.php. It's a form that allows our members to update their info on our databases. I've tried to replace DW's old Update Record server behavior with yours in the MySQLi extension. However when I look at the page locally, I get the error " Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in C:\wamp\www\2010 new site\update_self2.php on line 58". When I look at it remotely, I get a blank page in Firefox. Can someone look at the page and try to tell me what's wrong? Thanks, Gail
please send a copy of the page so i can see the code.
gail.bergan407744
Thank you, please see attached update_self2.php
in the update record behavior, you have the column values bound to the member ID recordset, use the form element bindings instead.
gail.bergan407744
See attached file; in the Update Record server behavior, even after changing the column values to be bound to the form1 bindings (I hope I understood you correctly), I still get a blank page upon opening on the server. Happens in IE and Firefox.
change line 58:
$UpdateQuery->addFilter("user_id", "=", "i", "$_GET['user_id']");
$UpdateQuery->addFilter("user_id", "=", "i", "".$_GET['user_id']."");
gail.bergan407744
I'm getting the same results. Updated page is attached.
gail.bergan407744
see link and attached site file. Thank you for your help.
the foreign column is still bound to the recordset:
$UpdateQuery->bindColumn("foreign", "s", "".($memberProfile_i->getColumnVal("foreign")) ."", "WA_DEFAULT");
instead of being bound to the form.
