dataassist search and pagination
hi
i create a serch page successfuly. when i search on page other then zero nothings listed. but recordset not empty. if i clik first button on pagination, i see search results. how can solve that?
baris.
hi
baris.
i updated the includes/musteriler.php file so that the sayfa URL variable would not be included when the search form posted.
another Jason Byrnes solutuions as usual. thank you very much. i wonder this solution is write way or quick solution?
The problem was that when submitting the search form, the pagination URL variable was a part of the action, causing the new search results to move to another page than the first.
You would want a new search to be at the first page, so the fix was to remove the pagination URL variable from the search submit action. I Don't see how that would not be the correct solution.
i just want to know. i add to my knowledgebase your last post. it is very usefull for me. thanks again.
