Undefined Errors
Thread begun 7/01/2014 5:27 am by randyrie405335 | Last modified 7/01/2014 8:46 am by Jason Byrnes | 1278 views | 1 replies |
randyrie405335
Undefined Errors
This PHP generated by the MySQLi recordset behaviors gives me a "Notice: Undefined index: xxxx in [path] " for nearly EVERY instance where I use the MySQLi recordset behavior. Here is a sample of the code lines causing the error (indented):
$rsSearch = new WA_MySQLi_RS("rsSearch",$JUA_i,1);
$rsSearch->setQuery("SELECT * FROM breakingnews WHERE breakingnews.Headline LIKE ? OR breakingnews.NewsArticle LIKE ? OR breakingnews.StartDate = ?");
$rsSearch->bindParam("c", "".$_GET['Headline'] ."", "-1xyz"); //varHeadline
$rsSearch->bindParam("c", "".$_GET['NewsArticle'] ."", "-1xyz"); //varNewsArticle
$rsSearch->bindParam("t", "".$_GET['StartDate'] ."", "xyz"); //varStartDate
$rsSearch->execute();
Google search reports (Stack Overflow) the error can be corrected by using isset(). Any ideas?
change:
$_GET['varName']
isset($_GET['varName'])?$_GET['varName']:""
This is a problem with the way Dreamweaver writes code for URL variable bindings, when you select a URL binding, Dreamweaver writes the code as:
<?php echo $_GET['varName']; ?>
more correct code would be:
<?php echo(isset($_GET['varName'])?$_GET['varName']:""); ?>
