Translations for eCart 6 jQuery Form Validation error messages
Where do I need to include translations for the default eCart 6 jQuery Form Validation error messages (such as "Please fill in this field" ...)
jquery errors are in the title attribute for the form elements on the cehckout page:
title="Please enter your company name."
I tried it but it doesn't seem to work.
Example:
<input type="text" pattern="[a-zA-Z0-9]+" title="Gelieve de veiligheidscode in te vullen" required="true" class="short" value="" id="Security_code" name="Security_code">
When a visitor leaves this field empty the error message in the tooltip mentions: "Please fill in this field."
Same for other form fields. Has this something to do with browser (language) settings?
It could be that you are seeing the server validation error messages, make sure you change the server validation errors also.
Where can I see/modify these server validation error messages? It is the first time I use the jQuery form validation feature so I am not (yet) very familiar with "where I can find what" ;-) I did a search on the error message but couldn't find it in the source code of any of the files.
I would need to see the page code to be abkle to give more specifics.
