WA Insert Record Server Behavior not showing
Thread begun 6/27/2014 8:03 pm by tolits | Last modified 4/10/2018 10:53 am by Ray Borduin | 6313 views | 9 replies |
tolits
WA Insert Record Server Behavior not showing when i wanted to edit my php.
How to restore the WA Insert Record Server Behavior?
Make sure you have Data Bridge installed, if it is not installed, the insert behavior will not show.
send a copy of your page please, so i can examine the code to see why it may not be displaying the behavior, if you have edited the code by hand, that may cause the problem.
tolits
Data Brigde - DataAssist Pages - Crashing all the time (Iam using latest version of DataBridge1.2.2)
I had followed most of the thread but not success.
Any other solution?
Please post your phone number, or if you are international a skype contact name in the private area of a reply to this thread and I'll give you a call to try to look into this with you.
tolits
Skype ID sent by PM
Looking to chat with you soon....
many thanks Ray!!!
Lito
I've added you to my Skype contacts. Please message me there when you see we are both online and we can schedule a good time to work together.
Allen
My Insert record was showing in my behaviors panel with no problem but within the last week or so it just disappeared from the panel. I'm using the MySQLi Server Behaviors and I hadn't had a problem with it until now. I've also tried using the update record behavior and it doesn't not seem to be working properly either - after I configure it it does not sow up in the panel either. Any help would be greatly appreciated. Thanks
Please post a copy of the page you are working on. I'll open it up in Dreamweaver and see if I can reproduce the issue and find the cause.
Allen
I've added the file you requested and a screenshot also.
That is odd. The page seems fine and the server behavior shows up for me. I see that a Datepicker Server Behavior is showing up in your screenshot. What is that from? It appears this may be a conflict with that extension.
