ecart tutorial question
Thread begun 6/26/2014 1:25 pm by Webbie | Last modified 8/01/2014 9:17 am by Webbie | 12374 views | 67 replies |
Webbie
I am browsing through the ecart tutorial II and am noticing the tutorial wants me to replace the add to cart button on my details page.
The question i have is all my add to cart buttons are on my product results page and i don't have any on my details page from doing the data assist create pages for my product catalog..
Should i do my results page instead of my details page? If so, do i delete all the add to cart buttons and replace them with the ecart add to cart button or will it automatically replace them all if i modify one of them?
And finally should i put an add to cart button on my details page as well so that a customer can purchase there... what button would i replace for that?
Thanks!
The results page uses a repeat region, so there is only one add to cart button there.
replace that with the eCart add to cart from recordset behavior.
And, yes, you can also add the eCart add to cart button to the details page.
Webbie
Thanks and i hate to bombard you but i need to learn this..
I used the ecart wizard to create my add to cart button but am having problems.
I could not find the brassy add to cart button, do you know where i can find that?
Also i added ecarts default button but did not realize it would change all the buttons including the details button so now there is no clear path to the detail page, could you guide in how to get the detail button link to be clearly marked or how i can fix the button?
Will attach a picture of what im talking about.
Webbie
Oh and since im selling a service that requires packages and wont have a price until later in the purchasing when they pick a package, can i delete the: <div class="WADAResultPrice"><?php echo($row_WADAProducts_2['ProductPrice']); ?></div>
on the results page so there is no price there or will that mess things up in the shopping cart in the long run?
Webbie
Bigger fish to fry
Ok,
Now i am having some more difficulties of coarse because i am a complete Newbie with databases and such.
I am on the add dynamic product options tutorial and am having problems getting my insert productname select list to populate the packages in the insert list on my add to cart options.
I know this may require some info on my end so let me start with my steps:
I studied the database in php my admin which i feel i have it pretty licked as far as comparing it with the tutorial, only i am using packages instead of colors for my needs. (Will attach a picture)
I studied each step religiously in the tutorial but i still cant find why my insert list is not populating, since your probably an expert with php and databases, was hoping you could use my FTP info and see what may be causing this not to fully work?
Hope to hear from ya, Thanks!
Webbie
http://ewebsolutionsinc.com/buy_package.php
Thanks man
You have this select list on a results page, the recordset for the select list is expecting a URL variables for Product ID which does not exist.
since you are putting the option select list on a results page, you need to use a nested recordset to return the otions for the curent product.
see this tutorial for details on nested recordsets:
http://www.webassist.com/tutorials/Display-nested-recordsets
Webbie
The data bridge nested record set diplay.zip file came back with the error "The file you selected is not a valid Data Bridge Application preset." Do you have an updated one?
Also before i tackle this tutorial do you think my add to cart and dynamic categories will work if i am doing the tutorial along with the details page as far as you can tell?
Should i just scrap the cart and dynamic checkout options on the product results page for now and redo it with the nested record set that the tutorial will teach?
make sure not to extract the zip file before using it.
when importing the preset, you need to select the zip file itself, not the folder that is inside the zip file.
if you extract the zip, you will get that error.
If you where to add the select list to the details page instead of using the results page, the list should work without the need for the nested recordset.
the nested recordset is needed on the results page because the idea of the results page is to display multiple records
"Where can i find what the variable for the recordset is set to"
in the recordset dialog box, it will show the variable being used for the recordset.
