Advanced options appearing out of order on web site
Thread begun 6/26/2014 11:34 am by sandy170299 | Last modified 4/27/2021 9:38 am by Ray Borduin | 6877 views | 16 replies |
sandy170299
On this product, http://zoeringdesigns.com/products_detail.php?ProductID=1, the options are listed in the order in which I entered them. On this product,http://zoeringdesigns.com/products_detail.php?ProductID=49, they are not, even though they appear in the correct order in the admin menu. How do I fix this? Thank you.
sandy170299
Please see PM...
on the webassist/plugins/shopping_cart/add_to_cart.php page, I Updated the option values recordset to order by the OptionID column.
sandy170299
Why was it working on one of the products, but not the other? Thank you.
There was no order by originally, so the order by was arbitrary.
I cant say why it worked for one not the other, i can only say that adding the order by fixed the problem.
Genuine COA
SImple Options appearing out of order
I have a similar issue with the Simple Options. They are appearing out of order. Can I switch this to be in the order that I entered them? Example is below:
https://www.genuinecoa.com/products_detail.php?ProductID=984
The order should be Event, Year, Publisher, Title, Issue, Pedigree, Value
Genuine COA
Simple Options Appearing Out of Order
Thank you, Jason.
Genuine COA
Please, see the private message.
