How to delete associated file with delete button from results page
Thread begun 6/25/2014 1:53 pm by Justin@AdventDesign | Last modified 9/17/2014 8:10 am by Jason Byrnes | 6694 views | 17 replies |
Justin@AdventDesign
If I've missed a tutorial somewhere, please advise. Everything I've found seems to be written before the delete record operation was changed in the "DataAssist Pages" wizard to perform the record delete on the results page rather than taking you to a separate delete page. When I insert the WebAssist > File Manipulation > Delete on the results page generated by the "DataAssist Pages" wizard, the WADeleteFile function deletes the last record in the entire results on the page, rather than the row in the recordset I clicked to delete.
How do I get the WADeleteFile function to select the record file name in association with the proper clicked row?
Here's the header code:
// WA Application Builder Delete
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
$WA_connection = $sitecontrol;
$WA_table = "tbSlides";
$WA_redirectURL = "tbSlides_results.php?id=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "id";
$WA_columnTypesStr = "',none,''";
$WA_fieldValuesStr = "".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
$WA_comparisonStr = "=";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_comparisions = explode("|", $WA_comparisonStr);
$WA_connectionDB = $database_sitecontrol;
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
if ($WA_redirectURL != "") {
$WA_DeleteFileResult1 = false;
if(isset($_POST["Delete"]) || isset($_POST["Delete_x"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../cmsimages/full/", "".$row_WADAtbSlides['photo'] ."");
And here's the code from the delete button in the row:
<input type="button" class="formButton ResultsPageButton unstyled DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAtbSlides['id']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" />
send a copy of the full page please instead of the code snippet.
Justin@AdventDesign
Results page attached...
Add a second hidden form element next to the WADADeleteRecordID one:
<input type="hidden" name="WADADeleteRecordID" id="WADADeleteRecordID" value="<?php echo($row_WADAtbSlides["id"]); ?>" />
<input type="hidden" name="WADADeleteFileName" id="WADADeleteFileName" value="<?php echo($row_WADAtbSlides["photo"]); ?>" />
edit the delete button onclick to pass the file name to the WADADeleteFileName form element
<input type="button" class="formButton ResultsPageButton unstyled DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAtbSlides['id']); ?>;document.getElementById('WADADeleteFileName').value=<?php echo($row_WADAtbSlides['photo']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" />
then edit the delete file behavior, and bind the file name to the WADADeleteFileName form element.
Justin@AdventDesign
Well that all makes very logical sense. I've followed everything and double checked it. Unfortunately, the delete button now does nothing. I reverted the page and it works fine with the obvious lack of deleting the proper file as said before. I suspected something with the "onclick" in the delete button but I'm not seeing why it should break the function, as I don't see any syntax issues and error reporting is showing nothing.
I've attached the revised page.
Justin@AdventDesign
See private message
Justin@AdventDesign
See private message.
Justin@AdventDesign
Must be a tough one...
Justin@AdventDesign
See private message...
