converting to mysqli
Thread begun 6/24/2014 3:09 am by Jamie | Last modified 7/01/2014 8:47 am by Jason Byrnes | 7246 views | 21 replies |
Jamie
Hi Jason
How would I convert this code to a mysqli version please?
$chk_rows = mysql_num_rows($SpecialOffersPanel);
if ($chk_rows > 0) {
mysql_data_seek($SpecialOffersPanel, 0);
$row_SpecialOffersPanel = mysql_fetch_assoc($SpecialOffersPanel);
<?php if ("".$showError ."" != "0") { ?>
<?php } ?>
and this one that i use with mod re-wrting
$colname_PageContentsPerm = "-1";
if (isset($_GET['perm'])) {
$colname_PageContentsPerm = $_GET['perm'];
$colname_PageContents = "-1";
if (isset($_GET['id'])) {
$colname_PageContents = $_GET['id'];
mysql_select_db($database_PowerCMSConnection, $PowerCMSConnection);
$query_PageContents = sprintf("SELECT * FROM services_plumbing WHERE ProductContentsID = %s OR Permalink = %s AND Live = 1", GetSQLValueString($colname_PageContents, "text"),GetSQLValueString($colname_PageContentsPerm, "text"));
$PageContents = mysql_query($query_PageContents, $PowerCMSConnection) or die(mysql_error());
$row_PageContents = mysql_fetch_assoc($PageContents);
$totalRows_PageContents = mysql_num_rows($PageContents);
All its doing is checking to see if the contents of the table have been set to live (1) or not (0) and if 0 then nothing shows in the front end
Jamie
The first code block is to reset the recordset to the first record. in mysqly, use the following:
if($RecordsetName->atEnd()) {
$RecordsetName->moveFirst();
The second code block is a standard recordset with parameters.
Examine the original recordset by editing it in DW to open the DW recordset panel.
Note the SQL and the parameters that are displayed, the names, type, default value and run time value for each.
then open the MySQLi recordset panel to recreate it.
Jamie
thanks for the reply Jason
Re the 2nd code block, I am able to get to a certain point:
$PageContents = new WA_MySQLi_RS("PageContents",$DBConnection,1);
$PageContents->setQuery("SELECT * FROM special_offers WHERE OffersID = ? OR Permalink = ? AND Live = 1");
$PageContents->bindParam("s", "".$_GET['id'] ."", "-1"); //colname
$colname_PageContentsPerm->bindParam("s", "".$_GET['perm'] ."", "-1"); //colname
$PageContents->execute();
but its the line from the original that I cannot see how to incorporate as mysqli:
that code:
is how the variables are added to the SQL.
in MySQLi, the variables are added to the SQL using these 2 lines:
Jamie
i cant seem to get it to work
I get the following on page error:
Notice: Undefined index: OffersID in C:\xampp\htdocs\street\promotion-s.php on line 6
Notice: Undefined variable: colname_PageContentsPerm in C:\xampp\htdocs\street\promotion-s.php on line 7
Fatal error: Call to a member function bindParam() on a non-object in C:\xampp\htdocs\street\promotion-s.php on line 7
Have attached the htaccess file and the target page
1) It looks like you used the same name for both variables in the recordset. When I open it in the recordset panel, the SQL shows as:
SELECT *
FROM special_offers
WHERE OffersID = colname OR Permalink = colname AND Live = 1
change that so it uses unique names
SELECT *
FROM special_offers
WHERE OffersID = paramOffersID OR Permalink = paramPermalink AND Live = 1
then create the variables as:
Type: integer
default value: -1
Run Time Value: <?php echo(isset($_GET['id'])?$_GET['id']:""); ?>
Type: text
default value: -1
Run Time Value: <?php echo(isset($_GET['perm'])?$_GET['perm']:""); ?>
Jamie
thanks Jason. Now its 404ing :(
404 is page not found. That sounds like a problem in the htaccess. what if you remove the htaccess file and access the page directly rather than using the rewrite rule.
Jamie
yeah I can access it fine if I dont use the rewrite but am just trying to convert the code that I have re-used multiple times but now to mysqli .....
MySQLi has nothing to do with the rewrite
something in the htaccess is causing the rewrite rule to malfunction.
