File upload clearing data from table
Thread begun 6/23/2014 2:16 pm by The Flying Fox | Last modified 6/23/2014 2:31 pm by Jason Byrnes | 1905 views | 3 replies |
The Flying Fox
My file upload on my update form is not working correctly, when the form is processed if the file field is blank the field is cleared from the table so becoming a null value.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../../misc/traders/docs/insurance/",
'FileName' => "".$_SESSION['trader_session_id'] ."_[FileName]",
'DefaultFileName' => "".((isset($_POST["insure_hidden"]))?$_POST["insure_hidden"]:"") ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["update_record"]) || isset($_POST["update_record_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "insure", "3", "[ExistingFileName]_[Increment]", "false", $WA_UploadResult1_Params);
form attached
Andy
this is because you have the disabled attibute set for the insure_hidden element:
<input name="insure_hidden" type="text" id="insure_hidden" class="form-control" disabled value="<?php echo $row_rsTrader['insurance']; ?>">
disabled form elements do not pass a value.
remove the disabled attribute.
The Flying Fox
Thanks Jason, I've changed them to readonly, this is what I thought I'd done in the first place.
Andy
you're welcome.
