URL rewrite syntax
Thread begun 6/23/2014 8:54 am by iainmacdonald331081 | Last modified 5/04/2016 9:57 pm by Ray Borduin | 5162 views | 6 replies |
iainmacdonald331081
URL rewrite syntax
This might be an easy one for someone, if not don't worry.
I have a URL rewrite that rewrites:
www.mysite.com/myfolder/index.php?myfield
as
www.mysite.com/myfolder/myfield/
Which looks like:
Options +FollowSymLinks
RewriteEngine on
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule ^(.*)/ index.php?GSG_URL=$1
However, I now need it to rewrite:
as
www.mysite.com/myfield/
But can't get anything I've tried to work.
your original URL is not valid.
URL variables should have a name value pair, for example:
?variable=value
if you have the originbal URL as:
www.mysite.com/myfolder/index.php?myvariable=myfield
that would be more correct. and you could use the following rewrite rule:
RewriteEngine On
RewriteRule ^([^/]*)/$ /myfolder/index.php?myvariable=$1 [L]
I used the mod rewrite generator here to find that:
http://ipdistance.laserprinterdrivers.com/mod_rewrite.php
iainmacdonald331081
Thanks Jason - yes, that was a typo in my original post - I did mean as you put it above.
I currently have a .htaccess file in the www.goodsafariguide.com/africa/ folder which looks like:
RewriteEngine on
RewriteRule ^([^/]*)/$ /africa/index.php?GSG_URL=$1 [L]
In an example where the GSG_URL value = alfajiri, this works:
www.goodsafariguide.com/africa/alfajiri/
But not what I'm trying to get:
www.goodsafariguide.com/alfajiri/
I cant offer a lot of support for htaccess, but:
"I currently have a .htaccess file in the www.goodsafariguide.com/africa/ folder"
it seems to me that if you want to force the URL To the root, the htaccess file needs to be in the root, not the sub folder.
If you need further support, you should post to a forum that deals more specifically with mod rewrite
iainmacdonald331081
Thanks for your help Jason - I'd seen a few other sites bout rewrites, but that one above looks the best I've seen.
I had posted elsewhere too - I know that with this sort of thing any help you guys can give is a bonus.
I pretty much have it working, but there are WordPress blog posts on the site which is causing a few issues. So the pages I want to appear all work, and most of the existing blog pages are unaffected, but a few of the blog pages display as the lodge.php page with no data.
UPDATE - think I have resolved it now - looks like blog posts with a / at the end of the URL were causing the page to break. But with no / they are fine.
jo271221
url rewrites
If I use an url rewrite mysuperpage/index?userid=456 as mysuperpage is there any way to still link from other pages of the site to a specific user id.
You can create your links with the same rewritten syntax. You will still have to pass the data somehow. So you could use a syntax like:
mysuperpage/456
Then have a mod rewrite that translates that to: mysuperpage/index.php?userid=456
and so on for any other pages you want to pass variables to.
