PMS removing code from editor
Thread begun 6/23/2014 12:51 am by scott417485 | Last modified 6/23/2014 2:32 am by scott417485 | 1074 views | 1 replies |
scott417485
Hi Jason or Ray
I have a site using Power CMS Builder, when I add code for an icon e.g. "<i class="fa fa-angle-double-down"></i>" and update the code does not show in the editor, the values are passed to the Content Value column in the database and the Content Value in the Content History DB, but within the PCMS editor in source view, the changes are not showing.
Normal text changes seem to work ok, e.g. changing a paragraph etc.
I have changed the DB table pcms2_contents column ContentValue from "TEXT" to "MEDIUMTEXT" as the client had reached the 64Kb limit for content.
Thanks in advance
Scott.
scott417485
Solved
Sorry guys
Have sorted out with following added to the ckEditor config.js file.
" config.protectedSource.push( /<i class[\s\S]*?\>/g );
config.protectedSource.push( /<\/i>/g );
CKEDITOR.dtd.$removeEmpty['i'] = false; "
