DataAssist update records & redirect problem.
Thread begun 6/21/2014 2:44 pm by Kumel | Last modified 6/25/2014 10:57 am by Jason Byrnes | 3390 views | 5 replies |
Kumel
All field are updating the record expect one. ie: Category.
& when clicked update file doesn't redirect to required page. it redirects to : /blog_Detail.php
where as i wanted it to go to /blog-details.php
edit the update record behavior on the page, make sure the category column is properly bound to the category form element and the redirect page is properly set to go to blog-details.php.
if you continue to have a problem, send a copy of the page.
Kumel
find attached.
the form action is to post to a differant page:
<form action="blog_Update.php?id=<?php echo(rawurlencode($row_WADAblog['id'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
it is set to post to blog_Update.php (PHP is case sensitive), the name of the page you sent is blog-update.php though:
<form action="blog-update.php?id=<?php echo(rawurlencode($row_WADAblog['id'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
Kumel
thank you
you're welcome.
