Receiving email not not form contents
Thread begun 6/21/2014 2:34 pm by Kumel | Last modified 6/25/2014 2:31 pm by Kumel | 3891 views | 10 replies |
Kumel
Receiving email not not form contents/field. Email received is blank.
To troubleshoot, remove the redirect from UE, change:
$GoToPage = "thank-you.html"
$GoToPage = ""
add the following code at line 1 to turn on error reporting:
error_reporting(E_ALL);
Then add the following code in the body tag:
<?php @session_start(); var_dump($_SESSION); ?>
this will write the session contents to the page including the email message, send a link where i can test the email after making those changes.
Kumel
private msg!
please include a link.
Kumel
Private msg
  I made those changes but something weird showing up!
I Dont see anything "Weird" showing on the page you linked to when i test it, it just shows a message that the email Successfully sent!!
Kumel
well i had made some changes by then. anyways this is what email i get : [file]
using a button:
<button class="send_message" id="send" type="submit">Submit</button>
wont submit the form
use the submit element type:
<input class="send_message" id="send" type="submit" value="Submit" />
Kumel
well form used to submit earlier. & even now it does. but still same result.. not receiving form details
Your page is using sending the form submit through using Ajax that is not properly configured to pass the full post.
I'm not sure where the ajax function is defined, but if you use Fire Bug to examine the page, it shows an ajax post being made with an empty post array. you will need to correct the ajax coding to fix the problem, where this is custom coding that is doing the ajax submit, we cannot offer support for this.
see the attached screen shot.
