I created an update form with form builder/datassist. Not working help!
I have tried debugging by echoing $sql. Update fields are blank. Form array not available?
In the update record behavior, on the Bindings Tab, you have bound all the fields using the recordset bindings, instead, you should use the form element bindings.
