Global Gateway E4
Thread begun 6/19/2014 9:32 pm by rob256926 | Last modified 7/15/2014 8:58 am by Jason Byrnes | 3851 views | 7 replies |
rob256926
Link Point Global Gateway E4
Is there a way to get Link Point Global Gateway E4 to work with eCart6? Any help articles on this?
You would need to hand code the checkout process using the Documentation from the gateway.
If you need help implementing an unsupported gateway, we can do this in a premiere support appointment:
http://www.webassist.com/premier_request.php
rob256926
Thanks Jason... Just scheduled the appointment.
you're welcome.
rob256926
Just had my cart setup to handle E4 payment gateway and am unable to take MasterCard payments. Any ideas what is happening?
On the failure page, add the following code in the page body:
<pre><?php @session_start(); var_dump($_SESSION); ?></pre>
this will write the session contents, including the response from the gateway, the gateway response will include details on why the transaction failed.
rob256926
for some reason I can't get the above code to work.
looks like I had a syntax error, sorry about that. the correct code should be:
